Interesting read on air filters
Old 11-13-2007, 10:59 AM
  #41
Saki GT's Avatar
K&N with proper oil (spray bottle ftw) + 5k mi oil/filter changes = you're golden when it comes to filtering air and oil. K&N lets in more dirt than OEM, but oil at 5k will have plenty of life left in it to handle it.
OEM paper filters cost $30 each, so its eaither $30/yr for a filter of $60 up front and spend the time to clean the K&N every 6 months. Its your call - $120 for OEM filters over four years or $60 for a K&N and cleaning kit and lets say 8 hours to clean it twice a year.
Old 11-13-2007, 12:50 PM
  #42
jyeung528's Avatar
how can you say that when UOA analysis shows that K&N filters cause higher wear rate metals and silicone, as mentioned above?
is your statement based on assumption or analysis?
Old 11-14-2007, 04:29 AM
  #43
TrackStar's Avatar
Btw our filters come oiled from the factory
Old 11-14-2007, 07:08 AM
  #44
Saki GT's Avatar
Which post are you referring to?
Imo, air filters help to keep oil from getting dirty, but its the oil that protecs the engine. A K&N, cleaned twice yearly, and a quality oil & filter changes at 5-6k mi should be fine. 5-6k is 67-80% of the Honda recommended schedule and a good match for a filter that lets in more dirt (and air).
Old 11-14-2007, 03:48 PM
  #45
jyeung528's Avatar
Originally Posted by slalom44,Nov 11 2007, 08:42 AM
There have been numerous UOAs posted on BITOG showing high wear metals using a K&N filter, along with the associated high silicon rates. Poor filtration doesn't result in engine failure. It results in the engine wearing out faster.
referring to the post above.
Old 11-14-2007, 03:49 PM
  #46
jyeung528's Avatar
it doesn't appear to be oiled to me.
it looks like green paper...definitely does not look like there is oil on it.
Old 11-17-2007, 01:56 AM
  #47
INDYMAC's Avatar
I use a K&N filter and have not found silicon levels to be abnormally high on two UOA's. I do have concerns about long term use as it relates to fuel dilution as a result of a recent comment from Terry Dyson (Triboligist) of Dyson Analysis on a UOA I posted on BITOG for my G35:
"For you folks that follow our work, understand if you are using a oiled air filter or a leaking filter that dirt,lubricant, or liquid can migrate to the heated MAF screens and once it hits 600-800 F will become a nice laquer or varnish forever riching the system. Why MANY on this board and those I see in analysis have consistent fuel issues with what should be a perfect burner."
I may switch back to the stock filter soon and call it a day!
Old 11-20-2007, 09:18 AM
  #48
Vik2000's Avatar
I'm glad I read this before purchasing K&N air filter. I'll be buying K&N FIPK Intake soon, hope there's nothing wrong with that one.
Old 11-20-2007, 09:42 AM
  #49
jyeung528's Avatar
the FIPK comes with a K&N filter....
rsdub
01-24-2017 01:08 PM
Twiztdsynes
03-20-2012 08:40 AM
dsthez
02-09-2011 07:39 AM
s2k-DC
11-29-2006 09:07 PM
vassosva
06-10-2002 07:40 PM
Quick Reply: Interesting read on air filters
