Installing Speed Bleeders
I have a set of Speed Bleeders arriving soon. According to the website, I just unscrew the old bleeders and screw in the new ones. This doesn't seem right, since brake fluid would run all over the place.
Do I need to drain my brake fluid before installing these? Or is there a trick to it? The same question goes for installing SS brake lines, as well: do I need to drain the system first?
Thanks, guys.
Thanks, guys.
You will get air in the lines on both installs - obviously more on the lines than the bleed bolts. Just do a good flush and you should be set. You may want to upgrade fluid while you are at all of this. then a very good flush is required to rid the system of the old fluid completely.
Billman250
01-22-2021 03:51 PM
frankyknuckles
07-02-2003 01:49 AM
