Installing a NTK Controller and Wideband O2 sensor????
Has anyone done this?
Will the sensor simply screw in where the stock #1 sensor is located?
Best location for the controller?
FYI, It will be hooked up to the AEM PEMS, which is already installed.
Yes it will screw in. The only complicated part is assembling the controller (if you're talking about the DIY unit) and wiring it up to the ECU. It uses a different harness, as well as the EMS will still be trying to drive a normal O2 heater. You will need to run seperate wire and wire the output from the controller up to the EMS.
Hershey
09-23-2014 06:32 AM
