installed vafc2 with frog-harness...need setting..
Hi, i am just installing the vafc2 along with the frog-harness...plug&play. Anyway, i searched the vafc2 setting and all i could find was the library of the vafc setting and so i go by the vafc(first version) setting. My car started but it won't hold the idle and die off on me. If i hold the gas then it will start right up....but if i let off the gas then it died on me....
And so i unpluged the whole thing and plugged back the stock and the car started up fine. If anyone are using the vafc2 on their S....can you show me your setting....i would appreciate very much....thanks.
Well first off go buy an AEM guage type wideband. Also someone may have setings but all of our s2000's run differently and all of our tuned will be different. I would suggest possibly letting youe local tuner dyno/street tune it for the best results! But i wouldnt suggest messing with it, with out a PLX or AEM wideband!
did you buy it used? if so, the settings from the previous owner are still stored on the unit. you're going to have to restart it and keep it at default settings until you can take it to your tuner. DO NOT try to tune it yourself without knowing what to do. Just take it to the tuner so they can dyno tune it with an a/f gauge.
i bought it used from Jotech motorsports(Kenny Tran). He used it for like 10 minutes on the Maxima. What happens was i forgot to set the A/F and all the adjustment points at 0. But yes i need to let the Tuner-shop do the tuning for me....that way i don't need to buy the wide-band....but it's good to have ones, lol.
If i set every to 0 than i should able to drive it until i doing the tuning on Monday right?
Originally Posted by GPW03,Jan 6 2007, 09:09 PM
Why not have it towed to a shop and have it tuned properly? You would save yourself all of this grief your going through.
Yes...set all corrections to zero and you should be able to drive it to a tuner.
A VAFC is only as good as it's tuner. Make sure you use a well known and respected tuner in your area. Tuning a VAFC is not for the inexperienced or you could set the a/f too lean, which could lead to a burnt valve.
BTW...are you sure this is a VAFC? Why did a Maxima have a VAFC rather than the SAFC...having a VAFC without a car with VTEC seems pointless.
