installed new fuel pump now 75+psi?
Hey guys just replaced my walbro 255 with a walbro 450 wired to the battery with the SOS kit. Started it up and I'm at 75psi. The 255 was about 45psi. I was told by my tuner I wouldn't need a fpr and could change pumps before I drove it in for a tune. 75psi seems very high to me. Is this normal with a larger pump? I emailed my tuner waiting to hear back.
Your fpr is overun by your fuel pump
You will need a fpr
change tunner if it dont know this you allmost doubles your fuel flow The stock shit will not keep up
And more pressure = less flow from the pump
75psi=350lph at 40psi=430lph
You will need a fpr
I haven't been tuned. Jeff Evans is my tuner. Said I wouldn't need a fpr with this pump and id2000s. I'm running my id725s now on my SC tune. Not boosting just driving like a granny to make it to his shop. But sounds like I will be ordering another AEM fpr :/
It's normal for the pump to increase psi after rewire mod. My went up 30+ psi just form the rewire.
I'm sure once you install the ID2000s I bet the pressure drops. Plus if your getting tuned who cares what your base pressure is but your tuner.
The injector size have nothing to do whit the fuel pressure
You will be really rich at 75psi
Look at this your pump is working harder draw more amp and lower flow
http://www.full-race.com/store/image...uel-pump-3.jpg
http://www.full-race...fuel-pump-3.jpg
Sent from my iPhone using Tapatalk
