Insane Axle vibration
I recently purchased a set of 500HP insane axles. I'm getting vibration under acceleration. Is anyone using these axles? I know about swapping inner cups on old axles but these are brand new. Any suggestions?
If they are not as thick then they are most likely solid axle shafts, this is why you have a vibration. Solid shaft axles are more susceptible to vibration in our car then the factory hollow axle. The vibration issue comes up quite often after someone has replaced their axles. Do a search on the site it's very common and annoying at the same time.
