Input Shaft Bearing or Throwout Bearing Failure
Does anyone have experience with either Input Shaft Bearing failure or Throwout Bearing failure? I may be experiencing one of the two. Looking for any first hand descriptions of the noises or behavior of either of these. Anyone currently experiencing one of them, a video or sound byte would be fantastic. Just trying to diagnose the problem outside of a shop. Thank you.
The Throwout Bearing on my car went out last year. I took it to a mechanic who was familiar with the s2000 and was told that it's a common issue on the AP2s.
I have been driving the car with the bad bearing for about 8000 miles now, and the noise is awful, but the clutch engages and shifts perfectly fine. I'm getting the whole clutch replaced in a month though.
https://www.youtube.com/watch?v=O5X-0OTAcv0
^ That's my car.
^ That's my car.
^ That's my car.
^ That's my car.
Yes, the sound was not there when the car was cold because the RPM was still around 2000-2200. As the car warmed up and RPM dropped to around 1100-1300, it was more noticeable.
Another thing was when I stepped on the gas and the RPM went back up to around 2000-2500, the sound was completely gone.
I know there is a way to see if your clutch is bad by putting the car in 3rd when you're going around 10-15 mph and then flooring the gas pedal, if the car revs but the speed doesn't go up, then your clutch is bad. If the clutch struggles but revs with the speed, your clutch is good. (I'm not sure about the exact speed) Billman might know better.
^ That's my car.
^ That's my car.
I don't really know if it would ever escalate to an actual performance problem...
