innovative mounts
innovative mounts
I deleted the thread I made. gonna wait till all the facts are in. dont want to cause a panic about the mounts yet.
Isn't this the same issue a member saw mid last year?
https://www.s2ki.com/s2000/topic/875...ted-the-block/
Damn this is scary, I Installed my innovative mounts a few months ago. I did not use the oem hardware though(used innovative bolts/washers), I remember hand threading an oem bolt into the right (manifold side) front top hole and it bottomed out rather quick. It was clear that the oem bolt was too long because there was noticeable space between the head of the oem bolt and the washer against the mount. I don't see a problem here unless someone used the oem bolts paired with a lot of force to get them in.
Im going to inspect each mount hole tonight and report back.
Damn this is scary, I Installed my innovative mounts a few months ago. I did not use the oem hardware though, I remember hand threading an oem bolt into the right (manifold side) front top hole and it bottomed out rather quick. It was clear that the oem bolt was too long because there was noticeable space between the head of the oem bolt and the washer against the mount. I don't see a problem here unless someone used the oem bolts paired with a lot of force to get them in.
I do recall doing the same thing with the OEM hardware and finding that it bottomed out far too quickly.
What gets me about this is that the torque spec is only 28lb-ft. If you're busting out your block cranking on these bolts, you're doing it wrong. And by wrong, I mean: You shouldn't be working on cars yourself because you 1) cannot tell when a bolt is bottomed out and 2) you cannot follow torque specs.
