Injector connectors
I was waiting until I received them before posting the details but for anyone who wishes to do as I did and take a chance, they are item number 22 on this site: Fuel Injector Connectors, Plugs, and Connector Adapters for; Automotive, Truck, Marine And Motorcycle Injectors Note that there are two subtly different ones shown. I photographed mine and then compared it carefully with those shown. The one with the wider groove corresponds with the appearance of mine, so I ordered four. They are available as a repair item in disassembled form or assembled with a pigtail installed. If they are wrong I'm only out $20!
If it's only the clip on the connector that broke off, don't worry. I never even bothered to zip tie my broken clips. 1 broken fuel injector clip, both cam sensors, and #4 coil pack. Been broken for 2 years worth of hooning, if it was a problem I would have seen a symptom by now.
Maybe a little late for you, but in case anyone else needs some, I just installed these a couple weeks ago and they work great:
https://www.ebay.com/itm/183391824620
Had to cut off the old connectors and solder in these new ones, a little tedious but they're cost effective and clip in just like new.
Thank you, that's good to know. Perhaps i didn't explain sufficiently in my first post. I have two connectors which are intact, one which broke the fastening clips when I squeezed them and one which disintegrated in my fingers. I have no choice but to replace the last mentioned one and I am so concerned that the others may be on the verge of becoming like it that I feel that I must replace them all. My car is a daily driver and I don't want to be left stranded because one or more of these connectors broke while in use. The experience suggests to me that replacing these should be a part of a major service which should be performed at 100,000 miles. I have never experienced this problem with any of my other vehicles or any previous ones and I speculate that the material used for the body of the connector may be mis-specified.
I have received the connectors which I ordered and they are a perfect fit. I chose the repair kit and it is complete and ready to solder to the wires. Note that you insert the blue piece last since this locks in the metal connectors.
zittymchoop
04-30-2016 10:46 AM
