injector and combustion chamber cleaning
I was wondering what is everyone elses take on sea foam.
I was reading road rages sticky post on injector cleaners and I am pretty well convinced I should start using one and will probably go with redline's as road rage is using.
AS far as the sea foam, I have a 96 civic with 180k miles. The head gasket was replaced 2 yrs ago due to a pin hole that occured from over heating. (fan wire was severed)
Do you think running redline injector cleaner would clean up the combustion chamber or should I use sea foam or should I leave it as is? Or maybe just use redline to clean up the injectors but it won't do anything else.
Also I got my S in October and and it has 42k on it. What effects will redline have on it? What about cleaning out combustion chamber deposits on it?
Originally Posted by campbuds,Mar 18 2006, 01:36 PM
ok... what is fp60? I miss that one on the list and looking back at it I am not seeing it.
http://www.lubecontrol.com/
