Info/pics on install of hyper ground System
I installed a Hyper ground system and a new optima battery on Sat and came out today (mon.) and my battery is dead. I checked the ground to the battery and the positive wire and everything is tight, so i'm thinking I installed the ground system wrong. I connected one from the negative terminal to the chassis(same location as the battery ground), one from the negative terminal to the Block next to the belts,one from the negitive terminal to the intake manifold and one from the left side chassis to the same location on the intake manifold as the other ground wire.
If anyone has pics or info on where to connect each ground wire it would be greatly appreciated.
Former Sponsor
https://www.s2ki.com/forums/index.php?showtopic=262917
Try this out, I used these ground points also
Thanks. I have them hooked up to the valve cover, VTEC solenoid, intake manifold and to the chassis on the Rt and Lt sides. Still not working.
