Info on oil change
Old 05-01-2013, 12:40 PM
S2KBert's Avatar
Default Info on oil change
Ima do an oil change for my ap2 and it has 43k .Is my motor oil 10w-30 and what about the filter for my car ? How can I check if my tranny fluid needs a change or how will I know if its going bad and the differential
Old 05-01-2013, 12:48 PM
HvRRZ's Avatar
10-30 synthetic if you can. and just use the OEM oil filter.
If the trans has never been changed then def do it. Otheriwse I like to change mine every 15K or so.
Old 05-01-2013, 01:08 PM
Norccer's Avatar
Mobil 1 10w-30 full synthetic and OEM oil filter. Our engines burn through oil quickly so be sure to check it as much as you can.
Old 05-01-2013, 01:19 PM
S2KBert's Avatar
I thought royal purple good so where can I get the oem filter at
Old 05-01-2013, 01:23 PM
Norccer's Avatar
Mobil 1 was the OEM Honda oil which is why it is my choice. You can get the OEM oil filter at any certified Honda dealership. Just go to the parts windows.
Old 05-01-2013, 02:43 PM
redlineracing's Avatar
The OEM filter is good,but IMO Wix and Purolator Pure One are equally as good and are available at most auto parts places.I use Wix on all my cars listed below.The S2K takes the Wix 51334.
On the oil....I personally prefer Amsoil AZO Signature Series 0w30.
\rlr
Carolina
Old 05-07-2013, 12:29 PM
S2KBert's Avatar
Do they sell the Honda oem filter online
Old 05-07-2013, 01:01 PM
Themikewoo's Avatar
http://www.hondaautomotiveparts.com/
I use that site but with shipping it might be more expensive in the long run.
I am also not in the same country as you.
Have you read this thread?
https://www.s2ki.com/s2000/topic/558...iy-oil-change/
Old 05-07-2013, 02:18 PM
S2KBert's Avatar
Yea thanks for the info I need to check my tranny fluid and differential but is it recommended to take it t a Honda dealer
Old 05-07-2013, 03:56 PM
dwight's Avatar
I would never recommend taking your car to the dealer.
Quick Reply: Info on oil change
