info needed for engine swap
Hi! After introducing myself HERE i wanted to get technical..
I need some specific info which i could not really find on the internet, so i figured to ask the guys who know all about these cars! Info is rare as this is something that has not been done before...
The plan:
Put a Rotary engine in the S2K chassis..
Not just any rotary, but the one i have been building and perfecting to suit my needs for 7 years.
Going to run a new standalone next year which will eliminate any real communication or wiring between engine and car, as it will have a full digital display to provide me with all the info i need. (Except the fuel gauge i think)
I will probably need more info later on, but these are the most important basics.
The measurements I need:
Distance between shifter and engine mounts
Distance between engine mounts
Distance between strut towers / chassis beams
The pictures i need:
Picture of an empty engine bay, showing the subframe and steering (some measurements included would be helpfull)
Picture of the front subframe close-up
Picture of the rear subframe and diff.
I do NOT want to start a discussion about wether or not to do it, why i shouldn't do it or any other pointless comment constructive criticism and helpfull ideas/info on the other hand are much appreciated!
If the measurements point out that it is possible, then there is a 99% possibility this will be put in motion.
It will not be a half-assed project, and with all the parts i have and can re-use, this should be able to run within a few months with the right preperation.
i am still in the research stage, as this project will not start within the next 2 years.
For now i am in the process of perfecting my Rotary setup in my RX-7.
Looking forward to your input!
Cheers
The plan:
Cheers
from front bumper: front subframe (w/motor mounts) and steering rack
from dash: front subframe (w/motor mounts) and steering rack
from dash: steering shaft and (partial) rack
from transmission tunnel: steering rack
from transmission tunnel: steering shaft
More at the album:
https://www.facebook.com/media/set/?...3&l=13447af9eb
Or PM me for any more pictures from certain angles/of certain locations. Will get post measurement of mounts tonight or tomorrow. - RJ
More at the album:
