immobilizer
immobilizer
I have a 2002 s2000 engine and trans with the stock computer i am installing in a 1969 datsun roadster i can purchase a aem computer or is there away to remove the immobilizer and reprogram the stock computer seeing that i don't need evap and 2nd o2 sensor. Thanks Dan
get a key reader and a key from and S2000 and have the key programmed into the ECU.n The key reader can be unbolted from the lock barrel and a key cable tied to the front of the reader. Its much easier if you can get a key already coded to your ECU when you buy it.
Moddiction
04-20-2011 12:16 PM
