im leaking oil
im leaking oil
im leaking oil from either my oil filter seal or my oil press adapter
i tight both of them down really snug and seem like its not leaking any more
but after i run the car a lil its still leak im pretty confuese
coz me and my friend tight both of them down really tight
and both the filter and the adapter r brand new
new seal and everything
what type of filter are you using? Is it an OEM or aftermarket? When you installed it, did it have an OEM or aftermarket filter. If aftermarket, the gasket could be faulty or the old gasket could have still been stuck to the block.
i have wix filter - i install adapter for oil press sensor then the filter on to the adapter
it seem like its leaking from the filter seal then i tight it , still leak
so i took it off and tight the adapter
then still leak
the wix filter it self i have use couple of them with no problem
but it just should leak from the adapter seal coz i snug them down really tight
then still leak
If I'm reading your post correctly you have a sandwich adapter and you can't figure out where the leak is coming from.
Here's a suggestion: Clean the area up really well, wrap a bunch of paper towels around the sandwich adapter & filter base, then take the car for a spin. Remove the paper towels and pay attention to where they are oil soaked. That will tell you where the leak is coming from.
You only have a few places that can cause a leak: The sandwich adapter O ring, the filter O ring, or the threads to the oil pressure sender.
i found it its the plug screw
coz i theres 3 opening im using 1 for oil press sensor , 1 for oil temp sensor
the thing is i for got to wrap tepflon tape around the plug screw
thanks
thanks
