i'm about to install coilovers...
ya know, once again s2ki people rule. particularly:
-gernby, i read your JIC stuff. thanks for the info.
-i'll have a 2nd person there with me, so that'll make my job easier.
-revhi, i keep hearing about the bolt too so i'm ready for it the day of the install.
-what the, i haven't read through the thread yet, but i can already tell it's going to make the job a little easier on the suspension impaired like myself.
i'm also ears to suggested settings for about a 20mm drop that'll keep me from rubbing and bottoming out. it's a street only show car. i'd track her, but ... well ... i don't trust myself when i get competitive. i'll drive over my skill for sure.
Originally Posted by pantyraider,Dec 21 2004, 12:10 PM
To get the lower arm to move down far enough on the rears you could also put the tire back on, and then use the scissor jack between the top of the tire and the upper fire wall. You can compress the wheel down far enough to remove the shock. It works well, and you don't need another person's help.
It is, however, the easiest way... but not the fastest.
And yes, I used the fork type.
If you have a helper, have that person stand on the rear hub (with the parking brake on) to maximize the clearance to remove / replace the strut. I've done this a few times, and it works great. Just place a chair next to the hub for the person to balance himself.
Also, if you haven't already read it elsewhere ...
Don't pop any ball joints on the front (or rear for that matter). Just remove the 2 bolts (on each side) that hold the upper control arm to the frame. This will allow the upper control arm to swing away, which gives plenty of room to remove / replace the struts. Don't tighten those bolts back down until the car is back on the ground.
