Idling Problem
Old 05-25-2007, 07:51 AM
iDomN8U's Avatar
This might be related to the IAC valve. Do a search
Old 05-25-2007, 09:24 AM
djpeak10's Avatar
not if it wasn't acting up before the TB was put on.
Old 05-25-2007, 09:59 AM
iDomN8U's Avatar
I would rule out the TB by putting back the old one and it still did it.
It could have been damaged in the reinstall.
Old 05-27-2007, 11:11 AM
JimmyB's Avatar
Originally Posted by iDomN8U,May 24 2007, 08:09 PM
changed the butterfly too?
If you are speaking of the TB Butterfly, why would I change it? It came with the new TB. I will be working on it later today to see if I can find the problem.
Old 05-27-2007, 11:49 AM
s2kBryan916's Avatar
If you have not done an idle relearn I would do that first.
Reset ecu, let set for a minute, reconnect and let the car idle for 5 minutes.
If this does not fix it then you have an unmetered air leak past the throttle plate. Did you use a new TB gasket?
If you adjust the screw on the throttle plate to close it more it may fix it but you also may be covering up for another air leak.
Start with the idle relearn and come back and let us know.
good luck
Old 05-31-2007, 05:58 PM
JimmyB's Avatar
I have tried the relearn & that did nothing as a matter of fact I tried it twice. My next move is to check for a air leak. I did replace the gasket. When I mounted the map sensor I also took the O ring from the old TB and put it into the new TB. Could the TP sensor be installed wrong or could it have gone bad. If so where can I get a new one?
Does anyone have any other suggestions as the engine is really ideling way to high and I am starting to get concerned.
I really need some help with this
Old 05-31-2007, 08:00 PM
JimmyB's Avatar
Hey guys I really need some help with this problem. Your help will be greatly appreciated.
Old 06-01-2007, 04:34 AM
iDomN8U's Avatar
Go back to stock and see the results
Old 06-01-2007, 07:12 AM
blackout's Avatar
Id vote air leak personally. Some of those bolts are a PITA to torque down and can come loose. Happened to me on my swap but no air leak oddly enough..
Old 06-01-2007, 07:26 AM
vspc2nr's Avatar
i think the screw below(brass flathead screw) is your idle screw. Tighten it turning clockwise, see what happens.
Quick Reply: Idling Problem
