Idling Problem
Old 05-24-2007, 07:02 AM
JimmyB's Avatar
Default Idling Problem
I installed a new Skunk 2 70mm throttle body and now the engines idles at between 1500 to 1800. Any suggestions on how to get it back down? I loosened the throttle cable, but that did not do anything. Help!
Old 05-24-2007, 08:05 AM
stphotographer's Avatar
Check and clean your Idle Air Controller (IAC) and the map sensor.
Old 05-24-2007, 08:40 AM
djpeak10's Avatar
Since it didn't idle like that before he installed the throttle body, I don't think that is it.
Old 05-24-2007, 12:46 PM
JimmyB's Avatar
bump
Old 05-24-2007, 04:27 PM
JimmyB's Avatar
Come on guys, someone must have a suggestion for this old guy!
Old 05-24-2007, 04:35 PM
04NickySP2's Avatar
Throttle cables too tight?
Old 05-24-2007, 04:40 PM
jeggy's Avatar
i dont know the details of the skunk TB but i do remember some older cars having a screw on the throttle body that allows you to adjust how mmuch the butterfly closes. a stop for the butterfly closing.
look for something that might be similar to that.
Old 05-24-2007, 04:42 PM
analog's Avatar
disconnect battery cable for 10-15 minutes. let the ecu adjust to the change when reconnected and driven.
Old 05-24-2007, 04:45 PM
JimmyB's Avatar
Thanks guys I'll give it a try and let you kinow.
Old 05-24-2007, 05:09 PM
iDomN8U's Avatar
changed the butterfly too?
Quick Reply: Idling Problem
