Idle Problems
Old 11-14-2006 | 08:12 PM
UniqueS2k's Avatar
Angry Idle Problems
I have Idle problems when ever i come to a stop sign and the car sometimes dies. I was wondering what can be the result of having idle problems? o2sensor, vacum leak, or what?
Old 11-15-2006 | 01:45 AM
SIIK2NR's Avatar
Couple of things to consider:
Map sensor whack might be needed.
Possible change in weather heat/cold.
Adjust throttle cable.
Tim
Old 11-15-2006 | 02:45 AM
donger274's Avatar
maybe something in your gas?
Old 11-15-2006 | 08:13 AM
Soul Coughing's Avatar
from reading the other threads recently... maybe you bent a valve?
Old 11-15-2006 | 09:21 AM
djpeak10's Avatar
Do not adjust the throttle cabel that is the job of the IAC.
Your IAC needs to be cleaned first off. I am willing to bet it is really dirty and causing your rough idle. If need be I will explain the process.
Old 11-15-2006 | 02:30 PM
Sniper_S2K's Avatar
Just do an ECU reset and go though the idle learn procedure see if that helps.
Sniper.
Old 11-15-2006 | 05:22 PM
modifry's Avatar
If it also idles rough and you have erratic off-idle acceleration - map whack. Otherwise, I'd lean towards the IAC.
Old 11-15-2006 | 06:05 PM
jeggy's Avatar
https://www.s2ki.com/forums/index.php?showtopic=386868
read it then go from there.
Old 11-15-2006 | 06:06 PM
myculito's Avatar
I think it might be important to ask whether or not you have any mods on the car.
Are you using anything other than the OEM intake system?
Old 11-15-2006 | 08:51 PM
UniqueS2k's Avatar
What is IAC? And how can i fix that?
