Idle air control
Idle air control
I have a rough idle when the engine is warm. I've cleaned out the IACV thingy on the side of the inlet manifold and it hasn't improved.
When I unclip the wiring to the IACV the idle speed raises to 1200 and steadily stays there, effectively solving the rough idle.
Any idea on why this is happening? Is it ok to leave the car running with this disconnected?
I'm supercharged with AEM standalone.
I am here: http://maps.google.com/maps?ll=55.125105,-1.507774
Sent from my iPhone using Tapatalk
Thanks for your reply, i had already cleaned the IACV. It's totally gleaming inside and it has been tuned by a Jeff Evans.
What I was asking is -
What does it mean if when the IACV is unplugged the idle smooths out and is it ok to run without the IACV connected?
I am here: http://maps.google.com/maps?ll=55.125163,-1.507982
it could be caused by a gasket leak. Such as the intake manifold gasket. I had a similar problem, my gaset was leaking it runner three as was causing a bad idle and a misfire. Also making the map sensor read out of wack. Not saying its it but you could spray some brake cleaner on the gasket while its running as see if you see any bubbles.. maybe the throttle body gasket as well.
