IAC valve Motor Adjustment
i found this DIY https://www.s2ki.com/s2000/topic/895678-shaky-idle/
from mr bullman250
Clean the IAC valve.
You will need a special tool called a pentacle bit. It's a five point torx.
Remove the valve assy.
Take the electronic motor part off the valve with the pentacle bit. BE CAREFUL...there are 2 tiny special shaped spacer plates between the valve and the motor. Work on top of a clean towel, dont loose them. Put it aside. Don't clean it at all in any way. A light wipe with a dry rag is ok, but it wont need it.
The VALVE part has a rotary shaft inside that spins 360 degrees. if it is sticking, the ecu input to move this valve will lag, and you will get the idle dip/shake/come back up. clean this out with cab cleaner, blow dry it. Even add a drop of oil to each end to the tiny shaft bearings.
Spin that shaft with with your fingers till it spins free and smooth.
from mr bullman250
