i over rev
Originally Posted by Venomous S,Sep 14 2004, 10:21 PM
You can get stainless steel valves for cheaper, not much cheaper but add here and there and it helps to save.
As long as you give for example Alaniz the stock specs of the valves, they will drop right in.
Also, I never found any that were cheaper than OEM. They were about the same price, if not a bit more ($17-28, plus a few bucks if you wanted oversized).
Originally Posted by mxt_77,Sep 14 2004, 10:26 PM
The problem I had when shopping for valves was that the dish on aftermarket valves tended to be larger than that of the OEM ones. So, if you got dished valves, you'd effectively drop your compression, and if you got flat-faced ones, you'd increase your compression.
not even alaniz had a set for you?
I know alaniz had a set for me, same exact specs, and if i remember my numbers correctly, I think i paid 17 or 18 per as opposed to honda, 23.
Originally Posted by Venomous S,Sep 15 2004, 05:45 PM
interesting.
Originally Posted by Venomous S,Sep 15 2004, 08:45 PM
interesting.
Originally Posted by yogi,Sep 16 2004, 02:38 AM
You'll also have a check engine light and a rough idle.
Also, where can one get a compression test done?
Originally Posted by SolReborn,Sep 16 2004, 08:07 AM
Will that always happen if your valves are bent? Could you have a bent valve and no CEL or rough idle?
BTW, what makes you think you have bent valves??
