i over rev
i over rev
i was driving and i finally decide to take my car 2 about 8500 and as i was shifing no power shifting just granny style shifting it went into 2 not 4th i was going about 80 at that point when i say it i push the clutch back in as fast as i can.... but now i think i bent a valve so i gonna have 2 replace it now in sucks... any one know how much r stock valves and where can i get them or should i just get todda valves
Originally Posted by kane.s2k,Sep 14 2004, 05:09 PM
congrats?
Always go OEM if you can. There's more to replacing valves with aftermarket ones than just replacing the valves. Same is true for everything else on the car.
I was congratulating him on that he got to rev a 2002 upto 8500rpms...still no 9000. But he's getting there. Maybe the next rebuild you wont be afraid to make it to 9000. I know it's rough...kinda like putting in.........
IIRC, stock valves are about $17-23 per valve. The valves are cheap, it's the labor that'll kill ya (since you have to pull the head).
Edit: See if this will get you there:
http://www.hondaautomotiveparts.com/auto/j...ALVE-ROCKER+ARM
$13 for Intake valves, $21 for exhaust.
You can get stainless steel valves for cheaper, not much cheaper but add here and there and it helps to save.
As long as you give for example Alaniz the stock specs of the valves, they will drop right in.
