I need some help
Hey guys I need some help I have a freshly built motor, I went to start it last week and it wouldn't start but was trying(a cylinder would fire randomly), we pulled the spark plugs and coolant was in all 4 cylinders. We pulled the intake pipe and there is coolant in the intake manifold. I thought it was the intake manifold gasket so instead of stock I went with the hondata heatshield intake mani gasket and installed it last night. We went to start it today and it fired up then died in about 5 seconds, so I pulled the plugs and sure enough there is coolant in all 4 cylinders. As of now Im hoping its not the headgasket. If you have any knowledge on the subject I would really appreciate some help.
Thanks guys,
Jordan
Thanks guys,
Jordan
Originally Posted by chris_barry,Feb 3 2011, 05:44 AM
check also that you havent mixed up some of the vacuum and water lines around the inlet manifold.
https://www.s2ki.com/forums/index.php?showtopic=844170
thanks for all the input guys I will check those two lines today but I just want to say billman250 you deserve a nobel peace prize with how much you help everyone out on this site, your the man!
