I NEED HELP! IDLE problems
i returned my car from FI to N/A and i am having problems with the car after i revit up the rpm's drop to about 100to 200 but the car never dies. it slowly builds back. i had taken it to honda the other day and they said i was having vacume leak from my injector seals, i ordered new and installed them today. after the install i was having worse idling problems after i rev the engine. please help i have no idea what it could be. and yes i have double checked all lines
Originally Posted by lexar13,Sep 13 2005, 08:55 PM
the ems is a direct plug in to factory wire harness so it is 100% factory right now
OK, just trying to determine the details of what you've done. Back to the issue of the fuel pump. The high output one still on? Just curious if maybe the stock FPR has faulted and you're running way too much fuel pressure.
no thats all i forgot :-). i checked the map sensor and did the steps you rcogmended in your other thread and if seems to be doing ok now but i dont know if thats a fluke or not so im about to go take it for a test drive.
