I lost 5th gear!! Help!
Old 06-08-2003, 02:38 AM
dave22's Avatar
Okay, my fluid is a reddish-brown color...nowhere near black. Still, the fluid will be changed to DOT 4 tomorrow and I'll post an update.
Also, 5th is getting easier and easier to use every time I shift
Hopefully I'll be as lucky as Tedster, but that never happens to me.
Old 06-08-2003, 04:10 AM
RT
RT's Avatar
OK, since you guys seem to be even lazier than myself, I found the info on the TSB I was talking about (would have thought Tedster had this as a shortcut on his desktop, Hint Hint Ted, better keep this handy for potential future ref):
[QUOTE]Originally posted by cerberus264
[B]I've copied this from a post I read two days ago because I can't find the link:
[Quote >>]
Here's the story...
I took my car into Keys Woodland Hills Honda for a variety of things.
1) Oil Change
2) Convertible not latching correctly, hence air leak over drivers side area over 75mph
3) Spark plug recall
4) Deceleration noise from 3rd or 2nd gear.
5) Transmission problem? Notchy gears, hard to get into 5th, 2nd, 1st or reverse.
6) Rear end pop/click noise when neutral to start forward motion or reverse motion. Basically, when starting out in 1st, I'd hear a short clicking noise from the rear or when I stop and then go into reverse, same thing. Anything to do with an initial force to the driveline, there's a couple of audible clicks or pops then goes away.
Conclusion/results,
1) Cost me $26.95 (thanks to 10% off Honda Club membership)
2) Adjusted convertible, no air leak anymore.
3) Replaced spark plugs
4) Performed TSB 00-054 (I pretty much think everyone knows about this one already).
5) Performed TSB 02-046 (This is new that I didn't know about and not in s2ki.com faq list of service bulletins). Sorry if this was a known bulletin to everyone before and this is a repost but I never heard of this one yet. Maybe this supersedes TSB55? Pics of bulletin down below.
6) Performed "NOTE" from Honda for solution. Basically replace spindle nut on axle and torque to 220 lb-ft. Didn't know about this "NOTE" either. Pics of NOTE below.
I'm glad to say that they fixed everything intended and only charged me for the oil change. It took them 2-3 days to do.
Old 06-08-2003, 04:13 AM
RT
RT's Avatar
BTW, dave, don't bother changing the clutch hydraulic fluid, it ain't your problem .......................you might think about changing the air in your tires though
Old 06-08-2003, 04:40 AM
PWRMKR's Avatar
It looks like 02-046 is just a lube job due to moisture in the shifter housing.
Old 06-08-2003, 09:49 AM
RT
RT's Avatar
so start lubing ..........
Old 06-09-2003, 03:07 AM
dave22's Avatar
Too late...I already tried that. It didn't fix the transmission though
Old 06-09-2003, 05:40 AM
PWRMKR's Avatar
ok, ok. Don't get pushy .
Old 06-09-2003, 08:51 AM
slalom44's Avatar
RT: Your postings were very informative, and many of us truly appreciate the knowledge passed along on this issue. Although I don't have this problem, I find this type of information helpful in better understanding my S2000.
I hope you aren't offended by this but I sense sarcasm in your last several posts, as if to cut down Xviper and others for giving bad information. Everyone was genuinely trying to give constructive advice, and in this case, you knew something that the other posters were not aware of. Kudos to you for your help. Maybe you weren't aware of how you responded, but in the back of my mind I was thinking to myself, "Gee, it looks like RT has the answer to dave22's problem. Too bad the answer came from someone that is copping a 'tude".
One thing that I admire about Xviper (and Cdelena as well) besides the knowledge that he passes on to others is the fact that he doesn't try to cut other people down for trying to give constructive criticism. He's right most of the time, and even when he doesn't pinpoint the problem dead-on, he (and others) give great input that help greatly in my understanding of this car.
Old 06-09-2003, 11:04 AM
RT
RT's Avatar
[QUOTE]Originally posted by slalom44
[B]RT:
Old 06-09-2003, 12:57 PM
PWRMKR's Avatar
word
Quick Reply: I lost 5th gear!! Help!
