I have issues
I am telling you guys it is nothing to do with the slave or master or how I did it. Give me some other ideas please. Today it actually grinded coming out of first gear.
Im also haveing a very similar issue are you with the tranny, grinding 2nd gear. I had it pulled apart and looked at by 2NRWerks because I thought it was the 1- >2nd gear synchros or gears and per their inspection the synchros and gears looked pretty good, so Im lost as to what the problem could be, but maybe we could solve it together with what our outcomes are. Also i have the squeaky and sticky clutch pedal, the slave was wet and the master had spewed grease out underthe dash like the gasket had blown, so I had it replaced there, the mastaer and slave and the squeak and rough sticky shifting are still there.
I don't know what my issue can be. Me and Radfox went through a lot of shit, and it is one big a55 mystery. Maybe I ahve a bent shiftfork, but I don't know cause it is affecting all the gears not just one or two.
radfox Posted on Feb 25 2007, 05:01 PM
Is the shifter itself lubricated enough?
Are the nylon bushings still ok?
A broken lower bushing may be your problem..
Just throwing it out there.....
.... but I have felt resistance before it pops into gear when the car is wrapped out. ....
