i had a pretty bad day yesterday
Old 09-15-2024, 05:40 PM
  #31
bad_driver's Avatar
Can you measure for crankwalk if we all suspect it to be a shot thrust bearing? If it exceeds the tolerance, probably good enough time to get the bottom end rebuilt, assuming we do not have catastrophic damage everywhere.
Old 09-15-2024, 08:07 PM
  #32
Rewire's Avatar
so, set up a dial indicator against the crank bolt, sit in the car, and press in the clutch, right? to check for crankwalk?
windhund116 (09-16-2024)
Old 09-16-2024, 08:30 AM
  #33
windhund116's Avatar
Received 1,533 Likes on 1,037 Posts
Sometimes, you can visualize excessive play by just pressing the clutch pedal in and out.
Old 09-16-2024, 08:51 AM
  #34
engifineer's Avatar
Received 1,444 Likes on 1,084 Posts
Make sure the transmission is in neutral when trying to turn the engine with a breaker bar. If you are still unsure you can pull the spark plugs too while trying it as that makes it a lot easier to turn. But with a long ratchet even you should be able to move the crank.
Ethan Reynolds
02-25-2019 09:47 PM
BigMeanBull
01-25-2005 02:39 PM
BigMeanBull
01-25-2005 01:41 AM
themadchef
01-09-2004 08:08 AM
BlackS2000Turbo
12-26-2002 01:14 PM
Quick Reply: i had a pretty bad day yesterday
