I feel dumb asking this... but
I've got a MY07 and for whatever reason I just can't find the OBDII port on the car. I tried searching and best I could find was someone saying it was driver side under the dash kind of between where the key is and the radio, but I've stuck my head under there and looked around best I could, but the only thing I found that looked close to the proper shape already had a plug comming out of it.
Is there a cover over it or something that I"m just missing? Anybody have a picture with the location?
Thanks.
Thanks.
I think I saw somewhere that it moved after 02, but I"ll keep looking... that or I"ll just cut a hole in the shape of an OBDII port, sick the device into it and hope it works
If you reach right under the steering column panel on the right side, up towards where the radio is mounted, you should find your OBDII port. I can now hook up to it without looking just from having to connect the OBDII reader to clear the CEL after so many miles because the Berk HFC is not playing nicely anymore.
Gambatte!!!
Gambatte!!!
Found it! Turns out that it's grey on my car and that its moved yet again... its in the corner of the molding recessed by where the dash meets the side of the radio... there is a metal support piece that is in the shape of a "V" right in front of it... the only way anyone can find that for the first time is if you lay down on your back and stick your head all the way into the car... good thing I just vacuumed my carpets for the first time in two years last week
bodo
11-30-2005 07:22 PM
