I can't identify which bolt goes here..
I'm not much of a perfectionist, but when a bolt is missing on the engine block/transmission, I'd like to make sure I at least identify what the heck the bolt is supposed to bolt down. While doing clutch myself, I found this bolt hole just empty. FYI this is on the engine block, on the passenger side. Does anyone know which bolt is supposed to go here? I can't find it in majestic no matter how hard I look.. the diagram for Auto Tensioner Bracket only shows the driver side of the engine.
First close up picture
A little more zoomed out. You can kind of see the header on top of the picture.
You can see the oem header and the bottom stiffener bar. You can also see another bolt missing just left of the red circle, but that was the clutch bell housing bolt that I was talking about in the beginning of this post. There is a bolt there now.
Your helps is appreciated!
There is a small bracket that bolts there the also bolts to that flange on your header. 90% of the time when I see them, they're snapped anyway, so I wouldn't worry about it. I haven't had one in my car for years and many miles.
very nice. nothing to worry about then. Thanks! Due to many stupid things prev owner did, I was getting paranoid about getting every bolt perfectly in their position.
darcyw
10-08-2017 06:49 AM
