I can't get the intake manifold off.
I'm pretty sure that I have all the bolts/nuts off the head/brackets. Does anyone have any insight on removing the intake manifold?
Thanks
-Anthony
Thanks
-Anthony
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Originally Posted by passmans2kny,Apr 4 2008, 07:07 AM
theres like 2 or 3 bolts under the manifold that were such a bitch to get to, if u got all those then i dunno
![iagree.gif](https://www.s2ki.com/forums/images/smilies/iagree.gif)
I think those r the 2 still on. I did that the first time I removed it.
Like stated before, you might need a rubber mallet to loosen it.
Originally Posted by ChefJ,Apr 4 2008, 10:41 AM
^^ Right on 5 above and 5 below the runners the 3 furthest to the back require some serious extensions and swivels and patience to get to.
just going from memory here but there are the 10 main bolts (well 8 bolts 2 nuts i think) and there are 2 bellow and then you have the two brackets one on the front and one on the side above the alternator.
It helps to remove the 3 hoses near the firewall. one is a pain because it has a double clamp on it. i replaced it with a screw type hose clamp.
this will let you see a bolt that you dont think is there =]
CrAzYNeSs
04-16-2005 09:17 AM
