I can only start using the "engine start button"
Engine start button seems to be my only method of turning the car over. It won't let me turn over using the key. When the key is in, dash lights up, EPS light stays on but when it turns over, EPS light is off and stays off. But I can't turn it over with the key, kind of like being blocked from the III position. Any ideas. New to the S2000.
Hmmmm! Sounds like a dealer issue. Something to do with the fusebox and a relay. The fetzer diode if I remember right. I would have it towed driving it could be bad.
Good Luck!
Good Luck!
