I broke the Rear Left Drive Shaft Axle
Old 02-12-2007, 03:27 PM
Yogi'sS2K's Avatar
Thumbs up I broke the Rear Left Drive Shaft Axle
I broke the Rear Left (Driver Side) Drive Shaft Axle, does this happen a lot? Is this common? The OEM Honda Part Number is 42311-SA-951 the (Description: SHAFT ASSY., L. DRIVE) List Price is $558.77
What other options do s2k owners have?
What would you guys suggest?
p.s. the s2k is n/a, has AEM CAI, Cat and Mid Silencer Removal, Clutch Slave Cylinder Delayer and filter Removed, Cusco 3 piece Brace, OMP Aluminium Strut Tower Bar , Tanabe Sustec GF210 (Orange ones) Springs, ACT Organic Sprung Disc, ACT Heavy Duty Pressure Plate. Broke 2nd gear last year changed all bearings in tarnny and 2nd gear and counter shaft 1K gone.
Old 02-12-2007, 03:33 PM
FISH22's Avatar
did the dealer deny warranty work with all your mods?
Old 02-12-2007, 03:55 PM
Slows2k's Avatar
Buy a new axle or look for a used one.
Old 02-12-2007, 04:02 PM
N/Apower's Avatar
Damn! How many splines are the S2K axles!?
Old 02-12-2007, 05:36 PM
Ruprecht's Avatar
How did you break the axle? Is this something that happens from mechanical defect, impacting a curb, clutch drop or what?
Old 02-12-2007, 05:49 PM
Markk's Avatar
I think what the OP is trying to say is he beats the crap out of the poor car. The first casualty was second gear.
Old 02-12-2007, 05:56 PM
Yogi'sS2K's Avatar
Thumbs up
Yes they denied warranty. Which I don't totally disagree. But I did disagree with them last year when they denied the warranty with the 2nd gear counter shaft and gear. I made them send the broken 2nd gear part to Honda Japan, they said it was from downshifting. So my advice is try to use heal and toe or rev-it up a bit before letting the clutch go when down shifting.
Back to the topic, what do you guys think of modified non-OEM drive shaft like?
What are my options? Any good Brands?
On the web I could only find used and new oem part and this stage 2.9 or stage 5.9 unit. Is it worth it? Would these drive shafts be noisy? Or harsh (not smooth)?
2000-2006 Honda S2000
2.9 500HP---------------------------------------------------------RA2000X2------RA2001X2
5.9 1000HP Axle/Hub Kit-----------------------------------------------------------------HS35
1-Piece Steel (prop) Driveshaft------------------------------------------------------HOSH1-S
1-Piece Aluminium 4"(prop) Driveshaft--------------------------(Soon)------------HOSH1
S2000 w/ Inline Pro R200 Diff Conversion Level 5 System--------------------------IN10
*Available through Inline Pro only-Kit includes 2 Axles/Hubs/Studs and Conversion Driveshaft*
http://www.driveshaftshop.com/S2000PAGE.ivnu
What do you guys suggest? Should I just get the Honda OEM part 42311-SA-951?
p.s. I
gomarlins3's Avatar
Agreed.
Old 02-12-2007, 06:06 PM
Yogi'sS2K's Avatar
Thumbs down
[QUOTE=Ruprecht,Feb 12 2007, 06:36 PM]How did you break the axle?
Old 02-13-2007, 06:08 AM
vtec9's Avatar
I believe the part number is 42311-S2A-951 (you forgot the 2 between S, A). You can purchase from slhondaparts.com for $461.66
Quick Reply: I broke the Rear Left Drive Shaft Axle
