Hypertune Intake Manifold
Old 01-28-2007, 08:43 PM
indebt&lovinit's Avatar
Default Hypertune Intake Manifold
Well it is done. After the lengthy install (install) and the hunting idle (idle) the car is running. We finally found the air leak causing the hunting idle: On the stock TB the two bypass holes on the left should have been blocked off by the intake manifold. Turns out that when i had it bored out more literally a 1mm sliver of air was able to get by the gasket. We happend to have gasket maker around and ten minutes of cutting later the car was finally idling. We then had to attack my hood cutting a big enough hole in the webbing to clear the TB/intake. I peiced together an old intake until i get out to Cody's, I know it looks like ass but I'm going turbo in April.
As far as performance the car deffinetly pulls harder, the biggest diffirence we noticed was the sound. Having cat back exhaust and at high rpms you couldn't hear the engine anymore, just the exhaust. Now the engine screams when you get on it. I'm sorry i won't be able to get any NA dyno numbers on it until maybe possibley perhaps when i go out to Codys and dyno it before the turbo install, again thats a maybe.
Here are some quick pics, questions are welcomed:
Old 01-28-2007, 08:50 PM
BlownAP's Avatar
man if they fix the issue with rubbing on the hood they will have a seller!
Old 01-29-2007, 04:30 AM
HARDtoTOP's Avatar
Is there a benefit of the air filter being placed near and angling toward the exhaust?
Old 01-29-2007, 11:24 AM
BlownAP's Avatar
hehhe,
yea man i know that intake is only temp. but you should think about some type of heat shielding from the radiator heat. It will kill your power
Old 01-29-2007, 01:53 PM
wildcardtrd's Avatar
interesting...
Old 01-29-2007, 02:22 PM
biker1's Avatar
Heres one I did earlier
Old 01-29-2007, 02:34 PM
Biker 1 where the hell were you for the last couple of months when i had all these issues... I just can't wait to get my turbo on and see the true potential of the intake.
Old 01-29-2007, 02:36 PM
^^^ Took me a second to realize that you have a RHD
I was like...wtf, how'd he get the battery on the driver's side?!?! ...Oh...
Old 01-29-2007, 02:49 PM
biker1's Avatar
Sorry, I had a bit of an accident a few months ago and was off the scene but if it
Old 01-29-2007, 03:46 PM
BlownAP's Avatar
looks like with this IM its easier to get to the lower manifold bolts/nuts....... which is a plus!
Quick Reply: Hypertune Intake Manifold
