Hydraulic Jack Placement?
[FONT=Arial]
This coming weekend, will be bleeding and flushing clutch and brake lines. I have jackstands and hyd jack for this
I am confident of where the jack stands go. But where does the hyd jack lift point go for lifting front and rear ends respectively?
Am also upgrading to a retro '03 non-DOV slave cylinder. For bleeding and access from the garage floor does anyone recommend jacking up the REAR half of the car or the LEFT half of the car.[SIZE=1][COLOR=green]
Be careful with positioning the floor jack when lowering the rear differential jack point, the exhaust pipes are nearby and it's very easy to dent the pipes if the floor jack is not position correctly.
Curated Content Editor
07-24-2018 02:31 PM
