Hybrid S2000 Engine?
Originally Posted by cjb80,Jul 24 2004, 04:58 PM
I would be willing to bet that the heads from a F20 and F22 are exactly the same anyways.
Just a thought. Again, I don't know if this information is accurate or not. I believe I heard it on an episode of Motorweek.
Originally Posted by julioar,Jul 24 2004, 09:23 AM
I like to use a 2.2 engine block, pistons, etc. with the 2.0 head, cams and computer.
Also I'm not sure for what kind of transmission mods. I need.
Please send me any info.
Thank you!
Thank you!
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-3yr.png)
Originally Posted by 00CivicSi,Jul 25 2004, 09:51 AM
I don't know if it is accurate, but I heard that the cam profiles had been modified as part of the upgrade from pre'04 to '04
List of difference that I'm aware of:
crank, rods, cams, valve springs (PCX -> PZX), rocker arms, retainers, valve cover & PCV breather, oil pump, oil jets (-010), flywheel, alternator (-J02), coil (PNA K-series common), exhaust header, throttle body, injectors
Things that are the same: block (short block assy is new P/N due to oil jets), pistons, head, oil pan & baffle, water pump, clutch & pressure plate, starter, auto tensioner, intake manifold
Some of the reasons why are not so obvious, like why the heck the alternator changed? Maybe just part commonization....?? Certianly is a lot more changes than you would expect for a stroker.
Originally Posted by Asura,Jul 25 2004, 04:57 PM
Is the '04 flywheel heavier than the previous years? We have felt this discernable difference on the 2.2.L.
Originally Posted by Ray,Jul 26 2004, 01:17 AM
04 has dual mass flaywheel for softer engagement.
Don't remember the weights exactly but it was like 6.8kg vs 9.3kg.
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Originally Posted by jlucas,Jul 25 2004, 01:58 PM
Dunno, can't look up that kind of stuff from home. I'll try to remember to check tomorrow.
