humming and clicking.
1.)after a night of joy riding, and a few 5th/6th gear pulls on the highway completely clear road against my friends turbo hatch, we come to a stop at the bottom of the off ramp. I proceed through a turn hard, a hard fish tail to the right while spinning, correcting, then proceeding through a gear or 2. I go to come to a stop, out of gear, neutral, and I hear a clickclick click...click.........click.........click as I'm slowing down it slows down, I was going STRAIGHT at the time of stopping. I'm not sure what it is, but I've never heard it before.
2.)The humming is something I noticed while I was cruising at a about 55 mph in neutral, it sounded as if it was directly under the car/shift boot, just a mellow hum not changing pitch too often.
Anybody know what the clicking might be, or tell me how to check what it could be?
Everything drives and acts as normal as it ever did.
Corey
Corey
its the rear, chunks of metal on the drain bolt, jacked it up let it idle in 6th gear whole bunch of crazy noises going on, about to pull it apart depending on the difficulty of it, I might have to start fresh tomorrow.
ouchers, what happend? if its chunky your ring and pinion might be shot, because if the lsd failed, it would lock up.........most likely, now im kinda worried, i click in neutral on hard turns, and dont hum but makes a wierd noise at partial throttle, no wierd noises though............well both of those are but you know what i mean
