hub replacement what parts do i need
i have that hub axle problem causing that clicking grunting noise i just bought hubs and i wanted to know if i should replace the axle as well and what other parts i need to get rid of that noise
You shouldn't need a hub unless you let the clicking become a squealing. If the bearing is still OK, the hub should be too. But...if you are sure you want to replace the hub, you should probably replace the bearing too.
Are you the one behind the torque wrench or is someone telling you they are torquing to 220ft-lb? Have you checked to see if the nut was properly STAKED? ( to CoralDoc...mister spell checker ) How many times has the nut been retorqued without replacing it with a new nut?
