how would i tighten the fit on my sidemarkers?
I was at a friends house last night and he looks at my car and goes "dude your side marker is broken", so then I look at it and it's just sitting there dangling by the wires. I popped it back into place and looked at it, and there were no scratches on it or anything so I highly doubt I hit something.
When I put it back into place, I could sorta still jiggle it a little. I just saw it last night and it was in a dark alley so I didn't have a chance to check it out that well because we were taking pictures and just wanted to hurry and finish up, but when I saw it after I got home from work, I noticed that there's no screws or anything to hold it in place
What do I do?
What do I do?
Is this the stock side marker? If so, then I suspect that the little clip may have broken and the only way to fix it is to get a new marker light.
If it's an aftermarket, then a lot of these don't fit very well and will show a gap. You may have one of these. In this case, you can bend the clip a bit in a way that will make it hold onto the mounting hole a bit tighter.
There's no other way it can just break off like that. Do you know where I can order a new one?
I think a small amount of clear silicone would do it, and still be easy to remove if the bulb ever goes. Just use enough to hold it - it is not a stressed member.
Yes, a small dab of clear silicone would work. If you ever have to change the bulb, you can scribe the silicone with a razor and get the marker off.
Or, you can order a new one from the dealer. Make sure you specify left or right side.
i'm pretty sure you can get one cheap from the members here on this board who have cleared theirs. not that i have my oem ones to sell, since i broke mine's getting them off... good luck with your find!
hey I have a set of oem's off my 01 that should fit you pay the shipping and I will give them to you for free.It's cool just tell me how to ship them c.o.d and I will.
they are just collecting dust anyways dude!!!!
dave
dave
