How to tell difference between OEM S0-2 and regular S0-2???
1 Post
Is there a way to identify whether a set of S0-2 are OEM S2000 are the different regular (or Porsche) version? Some type of identifing number? Thanks.
You should be able to tell by looking at the tread. The 205/55 has MUCH larger channels than the 225/50. I think the regular S-02s will have similarly sized channels, and may also be labeled "Pole Position" or "PP". I'm not absolutely certain, but it's a start.
The quick and easy method is that the S2000 tires are W rated, where the other S02s are Z rated, also the 89W and 92W specification is unique to the S2000 OEMs.
For more info:
http://www.tirerack.com/tires/Spec.jsp?mak...el=Potenza+S-02
205/55WR16 89W SL Honda S2000 front
225/50WR16 92W SL Honda S2000 rear
For more info:
1 Post
Thanks Jeff, the W rating is the quick and easy method.
[QUOTE]Originally posted by jeffbrig
[B]The quick and easy method is that the S2000 tires are W rated, where the other S02s are Z rated, also the 89W and 92W specification is unique to the S2000 OEMs.
For more info:
205/55WR16
For more info:
205/55WR16
Unicron
02-09-2001 03:45 AM
