how to tell difference between ap1/ap2 diff
just received my 4.56 installed diff from hardtopguy. other than opening the case to check what diff it is, how can you tell just by looking at its outer body? i have ap2 and asked for ap2 diff housing.
Because you got it from Hardtopguy, that's how.
As to the tech question,
There is no way to tell from the outside other than the pinion flange having larger holes in it for the 10 mm screws.
You would have to open it up to look at the bearing caps, that is the only way to tell.
If you bought it from Jeff then it is what he said it is AP2
