how to set timing!
how to set timing!
hey guys im in the middle of doing my retainers, and i need help setting timing. what notces on the bottom pully should i use. there is a pink one and white one.
i didn't have that info when i replaced my cylinder head so i just took a metal coat hanger and dropped it in the #1 spark plug hole and turned the engine over till the end of the coat hanger reached it's highest point. thats TDC.
Yeah that's what I was referring too. We torqued them down to 16 lb ft. I found what they where supposed to be at. Now I ran into a MAJOR problem. At first the car started fine, then the 2nd time I started it it had a weird sound. Then I continued on my way home and 15 min later I stopped at wawa and now my cel is on and my car won't start. Its making a weird grind sound after 2-3 cranks. I have no idea what's wrong. I'm terrified something is broken.
