How to resurface the flywheel at home
I know I read somewhere on here how to do so, but I can't find it now. I'm changing my clutch out tomorrow (ap1) and if the flywheel is okay looking, I planned on scuffing it up with some sand paper. What grit should I get? And what pattern should I sand at? IE criss cross?
Thanks guys!
Thanks guys!
I have cleaned up the surface on good condition FW's and PP's with sandpaper but it will not salvage a unit that clearly has wear or damage. I just us #100 grit paper and try to get a random pattern.
literally use the wax on wax off method. to create a sudo finish. they use something called bourdeless grinding to grind them from the factory and it uses opposing disks. so go around clockwise then counter clockwise.
Thanks guys!
Thanks guys!
ask Billman he resurfaced mine right in his garage real quick.
I understand it being cheap to have a shop to do it, but I'm a broke college kid! haha But thanks guys! I would have a shop do the fw, but I'm using a friends dad's shop and only have two days to do it so time is some-what limited.
