How resistant is the thrust bearing to damage?
Old 01-04-2011, 12:20 PM
SpitfireS's Avatar
#2 main bearing is at the rear
Well.. #2 is the first available crank main where you can put thrust washers at both sides.
Old 01-05-2011, 07:01 AM
Former Sponsor
Gernby's Avatar
The #2 bearing is at flywheel end of the block?!? Isn't that cylinder 4?! I figured the #2 bearing would be between Cylinder 1 and Cylinder 2...
Old 01-05-2011, 07:29 AM
SpitfireS's Avatar
Hmm...
I guess I'm the idiot here.
You're right.
Cyl #4 is closest to the firewall.
The crank has 5 main bearings.
That makes the bearing we talked about #4.
Are you reading this too Robert O?
Old 01-05-2011, 04:56 PM
Robert O's Avatar
Originally Posted by SpitfireS,Jan 5 2011, 08:29 AM
Hmm...
You're right.
I just did.And since I'm not incapable of error I thought you guys sorted that out very nicely.
Old 01-06-2011, 01:18 PM
slalom44's Avatar
Originally Posted by SpitfireS,Jan 4 2011, 03:02 PM
* another reason not the start the enigne with the clutch in.
I'm not sure what you're suggesting here. Unless you changed your stock setup, you can't start your car without pressing down the clutch pedal. The interlock disables the starter solenoid.
Besides - the added load would put additional strain on the starter, especially in cold weather.
Old 01-06-2011, 02:11 PM
Former Sponsor
Gernby's Avatar
Lots of FI guys disable the clutch interlock so they can start the car in neutral with the clutch engaged. I don't see how it would put a signficant amount of additional load on the starter.
Old 01-06-2011, 03:04 PM
SheDrivesIt's Avatar
Mostly irrelevant, I'd imagine. I've never really heard of there being a crank walk issue with S2000s.
Old 01-06-2011, 09:50 PM
SpitfireS's Avatar
slalom44 Posted on Jan 6 2011, 11:18 PM
In my honest European opinion, the clutch-in-to-start-safety-feature is in the same catagory as the "This coffey might be hot" and "Don't microwave your pet" warnings signs.
Actually, I used to start all the manual cars I've owned with the clutch in: to start the engine you don't need to drag the gearbox along.
After reading a post (or a couple, I don't recall) about crank walk on S2k's with the old style ACT PP I decided to stop doing that.
What I do know for sure is that ACT changed the spring design to lower the disengagement force while clamping force decreased only slightly, at the cost of some travel, compared to the old style ACT PP.
IMO (no matter what PP you have): no load on the thrust is better than a load, during a cold start.
Old 01-07-2011, 07:53 AM
crank's Avatar
the starter spins the tranny now along with the engine...although i too believe NO load on the thrust bearings is better during a cold start. I would rather replace a starter the thrust bearings
Old 01-07-2011, 08:06 AM
-Jordan-'s Avatar
^This.
You could ride your OEM clutch for years and not damage the thrust bearing surface.
Concider the fact that it only takes a couple hundred lbs to release the clutch pedal and the thrust is made from material and lubricated in the same way as the main and rod bearings. These surfaces see literal TONS of pressure on an ongoing basis. I guarantee you did not damage your thrust bearing in any way.
Also, find comfort in knowing that people run pressure plates twice as heavy as stock for thousands of miles of track mileage and abuse without damaging their thrust bearings.
Quick Reply: How resistant is the thrust bearing to damage?
