how to reset steering torque sensor - NO Honda PGM Tester
Old 02-04-2021, 01:56 AM
  #51
StarBar Hippo's Avatar
Default Honda Jazz EPS intermittent nightmare ?
Hi Thunder-rush and everybody else,
Need some help with a nightmare issue i am having with my Honda Jazz 2005 model.
Garage fitted EPS control unit and fault on EPS light coming on and going off at all different times persists.
The instructions you posted below my post here; was that done before or after you replaced the EPS control unit ? Like, are these control boxes just plug and play? I have the exact box for my model and totally baffled as are the mechanics to why the same fault persists after replacing control unit.
Any help or advice really appreciated.
Originally Posted by Thunder-rush
My EPS worked ramdomly, I did everything, traced wires, measure voltage,etc. In the end, bought a EPS unit in Ebay and was done for the day.
Here is the procedure.
With the car off, and the wheel straight do the following
1. Using a paper clip or backprobes, connect PIN 9 to PIN 4 on the ODBII connector.
2. Turn the steering wheel 45 degrees to the left
3. Turn the ignition switch on (II)
4. The EPS Light will be on for 4 seconds, when it goes out do step 5
5. Turn the steering wheel Straight, and release
6. The EPS Light will turn on in 4 seconds, when it goes out do step 7
7. Turn the steering wheel 45 degrees to the left
8. The EPS Light will be on for 4 seconds, when it goes out do step 9
9. Turn the steering wheel Straight, and release
now the EPS light will blink twice after you relase the wheel, within 4 seconds. then it will blink 5 times.
If the EPS light stays on, you will have to do this process again.
Old 02-20-2021, 02:28 AM
  #52
Can this all be done using a OBI/ data cable/diagnostic tool or, is this something that has to be specifically done using tis exact method ?
Have EPS light on for months and cant switch off.
Any help appreciated.
Old 02-20-2021, 05:09 AM
  #53
Chuck S's Avatar
Received 1,232 Likes on 1,076 Posts
The technique works to reset the power steering. You could have done it by now.
-- Chuck
eleven_b
01-05-2018 09:41 AM
Fmj03
07-17-2017 03:13 AM
Acid2o0o
02-26-2017 06:23 AM
crits2k
02-27-2009 09:03 AM
s2kbug
10-12-2001 10:06 PM
Quick Reply: how to reset steering torque sensor - NO Honda PGM Tester
