how to reset the ECU?
take off the negative from the battery or take out the back-up fuse for about a min. i hope you have the radio code..... it might be in your secrect compartment, but thats a secret... lol
Do not remove your battery cable to reset the ECU. Remove the no. 25 "backup" fuse (7.5 amp) from the cabin fusebox for 60 seconds. You will not need your radio code using this method.
Originally Posted by moey1188,Jul 4 2006, 06:56 AM
i have disconected my battery before and when i put it back in the radio still worked without having to put a code in. so if i pulled the fuse out would this make it ask me for a code when i put it back?
ps. Why are your resetting? It's not because you have a CEL, is it?
does any one no the code for the 2000 model with the cd stacker?
Originally Posted by dupmaronew,Jul 4 2006, 09:05 AM
arent you suppose to reset it if you put a new header on or some shit like that
xviper
10-03-2006 01:17 PM
