How to Replace a Door Skin
Has anybody had experience replacing a door skin on an S?
What is the basic proceedure? How hard is it? Anyone have actual instructions????
Actually, the skin can be replaced. However, the caulking around the skin will never be as uniform as the OEM one. I know this because my car was a victim of hit-n-run last year. If you get the door from Hardtopguy, it won't cost anywhere near retail. That's the route I went. Putting the door on and adjusting it is quite simple.
like skip said, replacing the door is a better idea than replacing the skin. i received a crease on the passenger side door from a hit and run as well. I contemplated re-skinning it, but under the advice of Jeff from Ganley, i decided not to. replacing the skin requires welding, and sometimes this doesn't turn out too well.
Thanks
I did some more reseach and found out you have to grind the seam off all the way around the door then the skin will come right off and, like you sad when you put the new skin on you have to spot weld along the top so I'm givng it serious consideration. I can get a new skin for $165 bucks and I have purchased a small spot welder as I have to weld in a rear quarter so i'm not sure which way I will go, I kind if want to give it a shot but don't want to botch it up, not being the expert body man. the 1/4 is going to be a challenge as it is! So far all the prices I have found for used doors are outrageous but I'll check out the hardtopguy like you suggested.
I just had another brainstorm (and now I have a serious headache.) I have a big time trashed driver side door so I think I will try grinding the skin off it just for the experience and to see whats all involved in the process.
I'll bet you'll find the crossmembers are bent and you'll have to replace it anyway! That was actually what happened to mine. They took the skin off and found it to be bent. Insurance then had to replace it. I had already ordered the door from Hardtopguy even though I would have to pay the difference. As it turned out, I saved a couple of days.
Originally posted by ayelien
Thanks
Thanks
