how to remove secret compartment & back panels
how do i remove the back part of the plastic rollbar headrest pieces and the secret compartment? i believe i removed all the screws attached to it, unless im missing any? should it pop right off? does anyone have a diagram of where the screws are located? thanks
I believe you have to remove the rollbars themselves to remove the plastic over the rollbars. The seam you see is not designed to be split and will not go back together if you do.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
The rollbar covers are not meant to be seperated from the bars. You have to unbolt the bars from the car. Not many have been successful at reglue-ing the covers. There are many screws that hold everything together, as well as multiple clips that hold the panels under the softop.
The Helm service Manual has all the documentation for interior removal, and LOTS of other info.
www.helminc.com
www.helminc.com
