How to reduce "tin-can" sound (exhaust + tp)
Old 12-10-2007, 12:02 PM
HMFIC's Avatar
you need a resonated test pipe......like the megans.......i had a regular test pipe......and it was raspy as i dont know what.......
Then put the resonated one........WONDERFUL....no rasp! and i have a HKS exhaust. I had Stock exhaust with NO resonator....sounded awesome....put on a test pipe..NON resonated.......BEE's CAN.......then i put the Resonated test pipe on the stock exhaust WITHOUT the resonator on the stock exhaust......Went away....
So either way.....you need a resonated test pipe.
Old 12-10-2007, 12:15 PM
Dark's Avatar
if you have a non-resonated test pipe then either use your stock exhaust or buy one for cheap and cut off the resonator so that it can be welded on to your test pipe. it will get rid of all the rasp and give it a bit deeper of a tone.
Old 12-10-2007, 01:03 PM
Amer's Avatar
Who else makes resonated test pipes? I think megan discounted them.
Old 12-10-2007, 01:33 PM
J'sS2K's Avatar
Dude, check out my post on Megan Resonated Test Pipe if you're thinking about buying one.
Jason
Old 12-10-2007, 01:59 PM
Amer's Avatar
Jason
In the other post you said you still get the same tin-can noise even with a resonated tp?
Old 12-10-2007, 02:02 PM
J'sS2K's Avatar
No no, check out my "Does this look OK?" post. I'm not sure what you mean by tin-can noise anyway, but I'll upload a video of how it sounds soon.
Jason
Old 12-10-2007, 07:28 PM
ncsu's Avatar
I just got my resonated test pipe off ebay for 36.99. I believe thats the only place to get them now and I also believe they are megan copies. That help?
Old 12-10-2007, 07:35 PM
Amer's Avatar
How do you like them?
Old 12-10-2007, 08:05 PM
JHooby's Avatar
my exhaust is stock and i have bees in a can!! is this normal ?
Old 12-10-2007, 08:15 PM
NVMY4N's Avatar
....is this with a TP? if so typically
Quick Reply: How to reduce "tin-can" sound (exhaust + tp)
