How often should you replace an after market intake.
Old 06-01-2003, 11:30 AM
BrandonS's Avatar
Default How often should you replace an after market intake.
I have an Injen CAI. How often should i replace the filter. Its been about 10-12k now, and i'm curious. Also, if i need to replace it, whats the best replacement filter. Thnx,
Brandon
Old 06-01-2003, 01:09 PM
xviper's Avatar
Doesn't the Injen have a reuseable, cleanable filter like AEM? Why would you want to throw it away?
Old 06-01-2003, 01:56 PM
BrandonS's Avatar
Its reusable? So what, i just take it off, clean it out with water, and then dry it?
Brandon
Old 06-01-2003, 02:24 PM
antek's Avatar
@BrandonS.
I hope you don't forget to oil it again...
Old 06-01-2003, 02:31 PM
BrandonS's Avatar
Oil it... i remember reading about that. Something about there supposing to be a little oil on it. Anyone want to shed some light on this.....
Brandon
Old 06-01-2003, 02:32 PM
xviper's Avatar
First, make sure it is reuseable. I'm almost positive it is.
Then, get yourself an air filter cleaning kit like the K&N one. It has two components to it. The first one you spray onto the filter and then run warm water to flush it out. You then air dry it thoroughly.
Finally, the kit contains an oil which you use to treat the filter. The kit will have complete instructions. The advantage of this kind of filter is that it should be the last one you will have to buy for your car. K&N brags that theirs will last 1 million miles. You should clean it annually or more often if you live in a dusty area.
You paid for a "lifetime" air filter. Don't throw it away.
Old 06-01-2003, 02:39 PM
BrandonS's Avatar
This is what i suspected all along, thnx for confirming it xviper. Your post are always to the point, thnx again.
Brandon
Old 06-01-2003, 08:01 PM
HondaS2000Tuner's Avatar
[QUOTE]Originally posted by BrandonS
[B]I have an Injen CAI.
Old 06-02-2003, 01:16 AM
ExOdy's Avatar
I would recommend using the cleaning kit every 5k miles. It gets dirtier than you think.
Old 06-02-2003, 06:11 AM
Former Sponsor
Gernby's Avatar
[QUOTE]Originally posted by HondaS2000Tuner
[B]
As far as I know never.
Quick Reply: How often should you replace an after market intake.
